Universal Devices
  • Home
  • Green
    • Title 24
    • RATES
  • Developers
  • Store
    • Cart
    • Terms & Conditions
  • Quick Links
    • Getting Started
    • Contact Us
    • My Tickets
    • Your Privacy
  • Headlines
    • News & Announcements
    • Plugin News
    • Developer News
    • Blog
  • My Account
Home / Smart Home / eisy r2 + Installation Support
eisy r2 + Installation Support - Image 2
eisy r2 + Installation Support - Image 3
eisy r2 + Installation Support - Image 4
eisy r2 + Installation Support - Image 5
$750.00
On backorder till 10/08/2026
Whether you are new to eisy | home or transitioning from a previous generation of our products, we offer a personalized one-on-one remote session to expertly handle your configuration and migration process.
eisy | home r2 is our 8th generation home automation controller and energy management system. It’s based on the same rock-solid technology as its predecessors while packed with raw power and flexibility:
Intel N150 Quad Core @3.6GHz | 8GB LPDDR5 RAM | 128 GB Storage | TPM 2.0
WiFi 5 | Bluetooth 5.1 | 1 x Gigabit Ethernet
USB: 1 × Type C | 2 × 3.0 | 1 × 2.0
HDMI: 2 + 1 on USB-C port
Available on backorder
SKU: eisy-r2-install Categories: IoT, Smart Home Tags: BMS, Dry Contact, OpenADR, Title 24
  • Description
  • Additional information
  • Reviews (0)
Description
eisy | home r2 is our 8th generation home automation controller and energy management system. It’s called eisy because it’s based on the same rock-solid ISY technology as its predecessors while also restructured for ease of configuration and use through our fantastic UD Mobile App. eisy is packed with power and flexibility and it’s so cute that some of us call it ‘cutie’! You don’t believe it? Checkout this video.
OpenADR Certified VEN:
eisy | home r2 is OpenADR 2.0a/2.0b certified VEN. You will also need an OpenADR certificate.
Please contact sales@universal-devices.com for more information.
Operating System:
Refined version of FreeBSD. UD manages building and maintaining the kernel and core/required packages. The OS and packages were designed to be easily field upgradeable and ensure that you configure once and run forever.
Device Support
  • Z-Wave, Zigbee, insteon, X10 all require external dongles (not included). Please check supported external dongles [ link ].
  • Matter Support (spec 1.3). Thread based Matter devices require a Border Router (not included).
  • 100s of other devices and services are supported through our awesome and vetted third-party developed node servers (plugins). Here’s the list
How Easy Is It to Setup?
  • Plug in the power cord to your eisy
  • If you have a WIFI network, nothing else is necessary. If you prefer using a wired connection, plug in an Ethernet cable to the network port on eisy. Ensure that your network is DHCP enabled
  • Install UD Mobile by scanning the QR Code below on your mobile phone:
  • Let UD Mobile guide you the rest of the way
  • WIFI Setup
  • Wired Setup
Migration From Older Generation Controllers
  • As long as you have a good backup, you can easily migrate from ISY994 (v5) and Polisy. It should be as easy as restoring your backup
  • Your ISY Portal licenses are migrated
  • Your node servers’ licenses are migrated
  • The only caveat might be migration of your Z-Wave devices. This said, a solution is in the making
Can I Attach It to Something?
Yes, of course. eisy comes with VESA mounts so you can attach it to the back of a monitor, wall, or whatever else.
What Do I Need the HDMI Ports For?
Nothing or everything!
Like most of us, you are used to low power and headless controllers which is perfectly OK. This said, the side effects of going powerful was that we got 2 x 4K HDMI ports for free.
So, we decided to give you full control to an awesome and light weight windowing system based on XFCE. So, what you can do with it is up to you including streaming 4K videos and listening to music through your Bluetooth headphones at WIFI 5 speeds.
And when get bored, just click on the IoX Finder icon to see how eisy is doing or visit our forum and participate in lively discussions!
Of course, you can use eisy in a headless mode. Windowing system will not start unless you start it manually every time you login. All you have to do is to plug in your monitor to one of the HDMI ports on the back of eisy, and once booted up, login and type:
start.win
Developers Heaven!
Imagine this:
  • Dual Monitors
  • Raw power to develop, test, refine, and submit your node servers on the same platform as your customers
  • Install development packages with one command
  • Stay in synch with UD vetted packages, configuration, and OS updates
  • Have access all packages offered by FreeBSD
  • As long as your node server does not require Polisy hardware, you are guaranteed that whatever you develop on eisy, will run on Polisy as well
  • Need more storage, extend it with and internal NVMe SSD to up to 1GB
P.S.
  • All services that run on eisy are developed on eisy itself
  • Do you want to install Home Assistant, go for it
  • You’re not yet a developer? Join our awesome developer program, huddle with likeminded geeks on slack, develop node servers, and make money!
Canadian?
For our dear Canadian customers, AARTech is handling all our sales in Canada. Here’s the link.
Weight 1 oz
Dimensions 7 × 5 × 3 in
Reviews
There are no reviews yet.
You may also like…
  • Serial PLM Kit
    Serial PLM Kit
    $26.00
    Add to cart
  • ZMatter USB Enclosure Only
    $26.00
    Add to cart
Related products
  • eisy Reflash USB Stick
    $52.00
    Add to cart
  • eisy | lite + Installation Support
    $590.00
    Add to cart
  • eisy | lite
    eisy | lite
    $399.00
    Add to cart
  • eisy | openADR
    eisy | openADR
    $572.00
    Read more
Back to top
Universal Devices
© Universal Devices 2026
  • Twitter
  • Facebook
  • YouTube
  • Instagram
  • Pinterest
  • Forum
Loading...
Insert/edit link
Enter the destination URL
Or link to existing content
