Universal Devices
  • Home
  • Green
    • Title 24
    • RATES
  • Developers
  • Store
    • Cart
    • Terms & Conditions
  • Quick Links
    • Getting Started
    • Contact Us
    • My Tickets
    • Your Privacy
  • Headlines
    • News & Announcements
    • Plugin News
    • Developer News
    • Blog
  • My Account
Home / obsolete / eisy | openADR
eisy | openADR
eisy | openADR - Image 2
eisy | openADR - Image 3
eisy | openADR - Image 4
eisy | openADR - Image 5
eisy | openADR
$572.00
Obsolete! Replaced by eisy r2 | OpenADR.
eisy | openADR is packed with power and flexibility specifically designed as a plug and play VEN for any configuration. With massive off-the-shelf device support, you can use it as a full Smart Home/Smart Building energy management system, develop your own plugins and seamlessly have your devices respond to OpenADR signals, use our feature rich REST APIs to get notified of OpenADR signals and events, or even use a simple dry contact closure. The possibilities are limitless!
Out of stock
SKU: eisy-openadr Category: obsolete Tags: BMS, Dry Contact, OpenADR, Title 24
  • Description
  • Additional information
  • Reviews (0)
Description
eisy | openADR is our certified OpenADR 2.0a/2.0b VEN based on our 7th generation automation controller and energy management system eisy | home. eisy | openADR is packed with power and flexibility specifically designed as a plug and play VEN for any configuration. With massive off-the-shelf device support, you can use it as a full Smart Home/Smart Building energy management system, develop your own plugins and seamlessly have your devices respond to OpenADR signals, use our feature rich REST APIs to get notified of OpenADR signals and events, or even use a simple dry contact closure. The possibilities are limitless!
For more information and/or OEM opportunities, please contact sales@universal-devices.com.
Specs
Hardware:
  • Intel Celeron Quad Core @2.9GHz | 8GB RAM | 60GB Storage | TPM 2.0
  • WiFi 6 | Bluetooth 5.2 | 1 x Gigabit Ethernet | 4 x USB Ports | 2 x 4K HDMI Ports
  • Internal NVMe slot can extend storage to 1TB
Operating System:
Refined version of FreeBSD. UD manages building and maintaining the kernel and core/required packages. The OS and packages were designed to be easily field upgradeable and ensure that you configure once and run forever.
Device Support
  • Z-Wave, Zigbee, insteon, X10 all require external dongles (not included). Please check supported external dongles [ link ].
  • Matter Support (spec 1.3). Thread based Matter devices require a Border Router (not included).
  • 100s of other devices and services are supported through our awesome and vetted third-party developed node servers (plugins). Here’s the list
How Easy Is It to Setup?
  • Plug in the power cord to your eisy
  • If you have a WIFI network, nothing else is necessary. If you prefer using a wired connection, plug in an Ethernet cable to the network port on eisy. Ensure that your network is DHCP enabled
  • Install UD Mobile by scanning the QR Code below on your mobile phone:
  • Let UD Mobile guide you the rest of the way
  • WIFI Setup
  • Wired Setup
Developers Heaven!
Imagine this:
  • Dual Monitors
  • Raw power to develop, test, refine, and submit your node servers on the same platform as your customers
  • Install development packages with one command
  • Stay in synch with UD vetted packages, configuration, and OS updates
  • Have access all packages offered by FreeBSD
  • As long as your node server does not require Polisy hardware, you are guaranteed that whatever you develop on eisy, will run on Polisy as well
  • Need more storage, extend it with and internal NVMe SSD to up to 1GB
P.S.
  • All services that run on eisy are developed on eisy itself
  • You’re not yet a developer? Join our awesome developer program, huddle with likeminded geeks on slack, develop node servers, and make money!
Canadian?
For our dear Canadian customers, AARTech is handling all our sales in Canada. Here’s the link.
Weight 1 oz
Dimensions 7 × 5 × 3 in
Reviews
There are no reviews yet.
You may also like…
  • ZMatter USB Enclosure Only
    $26.00
    Add to cart
  • Serial PLM Kit
    Serial PLM Kit
    $26.00
    Add to cart
Related products
  • eisy r2
    eisy r2
    $599.00
    Add to cart
    $750.00
    Add to cart
  • eisy | lite + Installation Support
    $590.00
    Add to cart
  • eisy | lite
    eisy | lite
    $399.00
    Add to cart
Back to top
Universal Devices
© Universal Devices 2026
  • Twitter
  • Facebook
  • YouTube
  • Instagram
  • Pinterest
  • Forum
Loading...
Insert/edit link
Enter the destination URL
Or link to existing content
