eisy does it again: OS 14.4, off-the-shelf Zigbee/Z-Wave dongle support, full program edit in eisy-ui, and more!
Big Things Are Coming to eisy
We’re excited to share that a major software update is now available. For detailed release information, please see [ this post ].
Here’s what’s inside in a nutshell:
OS Upgrade to 14.4
eisy is moving to OS 14.4, bringing your system up to the latest foundation release.
A Safer Way to Upgrade
We’ve redesigned the upgrade process from the ground up. Instead of upgrading in place, eisy now upgrades a clone of your system. Only after everything checks out does it switch you over to the new instance. That means you can freely switch back and forth between instances, or remove the one you no longer need. No more upgrade anxiety.
Support for Off-the-Shelf Zigbee/Z-Wave Dongles
You’re no longer tied to our Z-Matter USB dongles. Support has been added for off-the-shelf Zigbee and Z-Wave USB dongles (see supported devices). We’ve also fixed a few bugs, including Zigbee device removal causing a hang and Z-Wave hang issues some of you have run into.
Edit Your Programs in eisy-ui
If you’ve been using the Admin Console to manage your programs, you can retire it: the full power of program editing is now built into eisy-ui. It has the same familiar feel as the Admin Console, minus the extra hoops. Everything just flows.
Choose Your Update Channel
You can now pick which repo you want to track: staging, beta, or production, so you can choose between living on the bleeding edge or staying on stable, proven releases.
Smarter Backup/Restore
Backup and restore now includes system files, not just your configuration, for a more complete safety net.
eisy-ui: The Foundation for Retiring Java
This release also lays the groundwork for eisy-ui to fully replace Java, with a goal of finishing that transition by the end of the year, if not sooner.
Still on 994? Upgrade Made eisy!
Whether you choose eisy | home r2 or eisy | lite, migrating from your 994 is straightforward, and now more affordable than ever.
  • Use coupon code 3X9JCN2X for 12% discount on hardware (expires 08/31/2026)
  • Get 1 free year of ISY Portal
– Simple Instructions
  • For Insteon devices, migration is as simple as a backup and restore.
  • If you’re using a 500 series Z-Wave unit (models with ZW+), migration is just as seamless.
  • Your ISY Portal licenses and Alexa/Google Home configurations transfer with a single click.
  • Extend your system with hundreds of plugins: Click here for the full list
– What You’ll Need
We’ve prepared comprehensive migration instructions to guide you every step of the way: Click here for the full guide
Learn More About eisy | lite.
Thank you for being part of the eisy family!
